1 - 3 of 3 Posts
Quick question. I'm looking into trying to be kind of unique and I'm looking using some kind of pressure gague near the switches on the dash.
My question is this, has anyone observed the kinds of pressure found in a hydraulic suspension? Both in a lay amd play system as well as what kind of pressure can hoppers run? I'm sure there's a spike when the car is trying to bounce back up. And if someone monitored any of these things before.
How much pressure is in the system just to keep the vehicle locked up?
I kind of need to have an idea what pressures I'll be seeing. I plan on running double piston pumps at 72v
Thanks!
your not being unique carnal its been done befor back in early 1990's back when dinosaurs roamed california.
I said "kind of unique" lol
Since we're talking about the 90s. Why did the Reds and Porkys pumps with all the valves built into the blocks fade from popularity? If you got a lay and play setup, it looks cleaner than running rubber return hoses.
1 - 3 of 3 Posts
