What's up Playas... Got a question fo' all ya hydro Guru's. I recently replaced all 12 batteries in my vehicle. That is the only thing I replaced but now, my hydralic switches are acting funny. The front when touched so the car will raise just a hair, brings the front into the lock position. When I hit the back, the right side only raises up and locks. I changed the left rear Ford starters and that is all. What's the problem I am not seeing here fellas.... Peace............ One Luv...... ;)
J. Doz
If the front locks up in one lick of the switch sounds like maybe u put more voltage to the front pump. but other than that i would check the switch wiring, make sure ur wires to 24 volts on the switches and not higher, otherwise u can expect to burn the wires up if they are too small to handle the voltage
yes that too. gotta make sure u got the solenoids wired up to the 'S' post
