i need help on wiring up my hydraulics i cant figure out where the solenoids hook to
S s108switch · Registered Joined Aug 23, 2005 · 20 Posts Discussion Starter · #1 · Aug 25, 2005 Only show this user i need help on wiring up my hydraulics i cant figure out where the solenoids hook to
M Mikeb62 · Registered Joined Jul 23, 2003 · 404 Posts #2 · Aug 25, 2005 Only show this user CHECK TECH section on main page http://www.layitlow.com/tech/basichydrosetup.shtml
S s108switch · Registered Joined Aug 23, 2005 · 20 Posts Discussion Starter · #3 · Aug 25, 2005 Only show this user i did it dint tell me where exactly every thing goes
S s108switch · Registered Joined Aug 23, 2005 · 20 Posts Discussion Starter · #4 · Aug 25, 2005 Only show this user there is nothing on where the solenoids wire up too
M Mikeb62 · Registered Joined Jul 23, 2003 · 404 Posts #5 · Aug 25, 2005 Only show this user this shows all wiring http://www.layitlow.com/tech/basichydrosetup.shtml green is the wire that goes from switch to top of noid.... grey is the thick wire that connects from batt,noid to noid and then to the pump
S s108switch · Registered Joined Aug 23, 2005 · 20 Posts Discussion Starter · #6 · Aug 25, 2005 Only show this user what part of the switch do the noids connect to that is what it dont tell you
M Mikeb62 · Registered Joined Jul 23, 2003 · 404 Posts #7 · Aug 25, 2005 Only show this user if your looking at the back of the switch it should go on the bottom post. dump should be top post and constant 24v power to middle
S s108switch · Registered Joined Aug 23, 2005 · 20 Posts Discussion Starter · #8 · Aug 25, 2005 Only show this user that says front pump nothing about solenoids and then how do you hook up the other eight switches with it and the other 3 solenoids
M Mikeb62 · Registered Joined Jul 23, 2003 · 404 Posts #9 · Aug 25, 2005 Only show this user how many pumps? this is for 2 pumps. http://www.layitlow.com/tech/switches_8.shtml (where it says pump that would be wire that goes to top of noid) if this and this http://www.layitlow.com/tech/basichydrosetup.shtml dont answer your question then maybe I just dont know where your lost
S s108switch · Registered Joined Aug 23, 2005 · 20 Posts Discussion Starter · #10 · Aug 25, 2005 Only show this user thanks alot i see what your sayin now
S s108switch · Registered Joined Aug 23, 2005 · 20 Posts Discussion Starter · #11 · Aug 25, 2005 Only show this user do i do that for every switch and do i do one seperate for that back
M Mikeb62 · Registered Joined Jul 23, 2003 · 404 Posts #12 · Aug 25, 2005 Only show this user yes back will be seperate
