New here ... I just installed 10 inch cylinders in the back and took off the regular coil set up and installed powerballs now the car sways when I bring the back up and down . What can the issue be ?
I got the wildstyle
Instragram: Kiloz_One
What kind of car? if its a 65 Impala like your user name suggests, you probably want to go with a wishbone.
So basically you went from coil under to coil overs and now the rear end has travel due to the power balls.
Id look at your trailing arms to make sure everything looks good there too now. that travel could of messed with them.
2025041
