1 - 9 of 9 Posts
I BOUGHT A PAIR OF THESE, AND I WAS WONDERING WHAT FITTING I NEED.
I WAS THINKING THIS
CAN SOME ONE PLEASE POST SOME CLOSE UP PICTURES OF HOW THE HOOK UP.
I WAS GOING TO MOUNT THE RIGHT OFF THE DUMP, ON THE LINE TO THE CYLINDER. IM 99% SURE IM RIGHT JUST WANTED TO MAKE SURE
Off the dumps you'll need t- fitting... instead of the 90 degree fittings.... the t will have a #6 hose JIC hookup male one end will probally be 3/8 NPT male and I forget what the other is....
Bring em over... did you have them yet or r u still waiting craig?
True-S Mike
Originally posted by beyondstockcav@Jul 29 2005, 01:41 PM
where can I get a shut off valve at?  I see you have one and I need um, 4.
[snapback]3505607[/snapback]​
i was told the ones i have are not good and will soon give me problems :dunno: you can use regural slowdown valves. i will be doin that soon enough myself.
these work for now sence i only shut them off when jackin the rear up and needing to get under it. before then, the accumes would push fluid into the cylenders makin it pressurize when i was wanting it loose.
1 - 9 of 9 Posts
