Originally posted by bigdanmcintosh@Dec 8 2003, 07:00 PM
trailing arm, right where the stock spring went
;) That where I had mine
and when you drill the cylinder hole in the front springtowers be sure NOT to use the shockhole as a center because then the cylinder will grind against the bar that holds the upper a-arm. the hole should be drilled a little bit more out against the tire...
good to know
