1 - 2 of 2 Posts
G
i have a explorer with i beams and am not sure how the cylnders mount dont know much about hydraulics i usualy use air ride but i want to try something different i also would like to use springs if possible any info helps thanx
O.G. Poster
because your truck has the ttb setup in the frount it shouldent be too hard all you need to do is punch a 2" hole in the spring pirch (the bracket that holds the top of the coil) then cut down the coil to give you some movement but keep in mind the coil will settle in and become shorter over a week or two
1 - 2 of 2 Posts
