1 - 10 of 10 Posts
Today I got all my installation done so I was hitting switches it has two pumps. In the front I got marzzochis with gear #9 and on the rear I got the rockfords I think the #5 but my front pump is not lifting anymore same thing is happening to my cousin with the marzzochis and now we are not over locking it. ;)
I dont want to keep on replacing seals. ;)
Honestl, I think it isn't the heads messing up. From what I have seen they are pretty much the same. Maybe something else is going wrong in the system to make you blow seals like crazy.
Well is a brand new pump. :)
seems like you overtightened your pumphead, and it isnt sitting right, or isnt seated right on the block, take it off, but hopefully you didnt warp it :0
Not to diss showtime but i got a block from them that the machining was so far off that the pumphead pressure hole was so far off that it it didn't line up with the block u might want to check that.. if they dont line up u will blow seals..
Well, if your not overlocking your pumps then maybe it is what the other guy said and that the blocks are amchined wrong. I'm not sure what it is. Try a totally different pumphead and see if it keeps doing it.
Dammmmmmmmmmmmmmmmmmmmmmmmm it I m fucking dumb yesterday I did not notice that one of my front cylinder hose was loose and it leaked all the oil. So the pump just needed oil in the tank :ugh: Thanks anyways for all the help homies. :cheesy:
1 - 10 of 10 Posts
