1 - 14 of 14 Posts
Asspirating Poster
I am trying to push the piston in on my brakes. I'm using a c-clamp, and I've barely started pushing it and it's so hard to turn the threads that I bent the little bar at the end.
I can't imagine that it's always this fucking hard, so what am I doing wrong?
It's an '89 Camry if that makes a difference. I don't think the piston is the turn-type, either.
Asspirating Poster
The c-clamp is brand new.
I'm thinking maybe the piston is out too far or something. Like it slipped out of the cylinder or whatever.
I don't know that I'm doing something wrong, but it doesn't seem like it should be this hard.
Asspirating Poster
I did that just now and same problem.
I'm pushing so hard that some of the threads on the c-clamp started stripping.
Asspirating Poster
The hoses seem fine. It wasn't pulling, either.
What's that tool called? I tried using the pad on it and it still won't go in.
Asspirating Poster
I figured out what tool you were talking about - a hammer and a ratchet extension.
I took the caliper off all together and beat the piston in.
Thanks homies....
Syte Posted Today, 12:48 PM
Thanks homies....
:roflmao: :roflmao: :roflmao:
either the caliper was frozen or it came out like you said. i use a set of BIG slipjoint pliers to press them in. NEVER had an issue.
<<works on toyotas every days :biggrin:
Asspirating Poster
Discussion Starter · #14 ·
I don't know if it slipped out or not. When I started hammering, brake fluid started squirting out of the brakeline hole.
What happens when they freeze?
It works fine, now.
1 - 14 of 14 Posts
