here ya go!
KL1800 - 18 FUNCTION KEYLESS W/ BIRT
MSRP: $399.00 YOUR PRICE: $200.00
TAKE CONTROL! AutoLoc's exclusive 18 function KL1800 allows you to have total control over your vehicle from the palm of your hand.
From one four button remote you can roll you windows up and down, unlock and lock your doors, trunk, or hood, open/close your sunroof, remote start, turn on your headlights, neon, or dome light, alarm, operate your stereo, or anything else you can think of. With 18 channels of accessory outputs, you'll only need one remote to control everything on your vehicle.
AutoLoc's exclusive 4-button remotes make controlling 16 functions easy. No more pushing complicated button combinations, simply select the channel and send the signal.
Each of the 18 available channels offers programmable pulse times, allowing you to choose between pulse, constant, and latching outputs. AutoLoc's KL1800 also features Visual Parking Light Confirmation, Long Range Remote Controls, and AutoLoc's exclusive Shaved Door Handle Mode, which increases the efficiency of solenoids and actuators.
The AutoLoc KL1800 comes with two 4-button remote and plug-in wiring harnesses that make installation quick and easy. In order to ensure quality and performance, each KL1800 has a limited LIFETIME WARRANTY.
Smart & Fixed Buttons: AutoLoc's simple to use 4 button remote makes operation of your keyless entry system easy! You have 2 chooses standard button operation, or Smart button operation. No more push complicated button combinations! Simply push button 1, to lock your doors (channel 1), and button 2 to unlock your doors (channel 2). Push button 3 to select you channel, then button 4 to send the selected channel.
Example: To activate channel 6, simply push button 3 six times then push button 4.
Smart buttons make the KY 16x ideal for shaved door handle kits, or any applications!
The KL1800's Built-In Door Lock Relays work on negative, positive, and five wire systems, making wiring up the KL1800 fast and easy.
Built-in Door Lock & Unlock Relay: Stop wiring up external relays! AutoLoc offers B.I.R.T (built-in relay technology) resulting in one of the most reliable and easiest installed security system on the market. Compatible with all door locking systems, including reverse polarity! Built in relays increase reliability, while reducing installation wiring time by over 70%.
Code Learning: Lose a remote? Don't worry AutoLoc's KL1800 can learn up to 4 different remotes. Each remote has its own coded frequency to insure your vehicles protection.
Code Rolling Technology: Today's car thief uses "code grabbing" machines to duplicate a standard car alarm code. Once the car thief has the code he retransmits it out and deactivates the car alarm. At the same time the doors unlock and the car thief has full access to the car. AutoLoc's code rolling technology insures your car's safety by changing codes on the receiver after each transmission. To insure maximum protection AutoLoc's code rolling technology also allows you to delete lost or stolen codes.
Parking Light Output: This allows the unit to flash the parking lights once on lock and twice on unlock. This visual conformation insures your vehicle's safety. The lights will also flash anytime a channel is selected on the remote.
Limited Lifetime Warranty: In order to insure top quality AutoLoc's keyless entry systems are made backed by a limited lifetime warranty.
