1 - 20 of 22 Posts
had a litle rouble wih bitch ass verizon talking about it takes 10 days to set up my dsl
bu it's up now.
what have i missed?
i replied to your pm's b diddy1 i was kinda late but whatever
bu it's up now.
what have i missed?
If you are gonna be away for an extended period of time, I expect a heads up!
did you take care of all that stuff you needed?
Asspirating Poster
You bring any updated pics? If not, go away again.
yeah joe, with out layitlow you must have had some extra time on your hands. please tell us you got some work done on that 52.
Yep. I figured it out, by re-reading our original discussion about the valve wiring from about a month ago.
Project Progess Update ...
1.) York Installed, Wired to Relay, Filled with oil, Intake filter installed, and airline ran to trunk. (Tested and clutch engages when 12V sent to relay)
2.) Both driver side and passenger side air lines ran to trunk as well as the incoming air line from the compressor
3.) Pressure switch and switch box power wire ran from accessory power fuse, through a toggle switch, and out back to the trunk
4.) "Signal" wire ran from pressure switch to relay under hood
5.) Trunk "liner" made of wood carpeted and installed in floor trunk.
6.) Tank mounted to "liner"
7.) Pressure guage mounted on left hand port of tank
8.) Adjustable 400 psi pressure switch ran to top of tank, via a L-shaped fitting which allows switch to sit horizontally / parallel to the top of tank
9.) Pressure switch wired
10.) Drain cock installed
11.) All 8 vavles plumbed, and wired to switch box.
Still need to ground my valves, hook up my check valve, pressure relief valve, and coalescing filter to the incoming airline and connect to tank. And the major part ... install some fucking bags. I am putting in the 13" bags this weekend. I am a little intimidated by the front end, so I am a dragging my feet on ordering them. I am not sure if I can handle the front install.
- Brad
- Brad
didn't you buy the brackets from dan?
making the correct brackets is the hardest part
aside from trimming the pockets if you don't have the right tools
and taking out the coils
i always ciut the coils out in peices with cutting wheel
on old cars
or torch them out
or the jack under the lower arm
and disconnect the shocksa and upper balljoint
torch is fun
on old cars
or torch them out
torch is fun
yeah I bought brackets. they worked great (with a little modification) I am just not sure what all needs to be done in order to take apart the front end and put it back together. I am not exactly johnny backyard mechanic over here!
well i got them skirts to fit with some trimming and new mounting bracketry
but that is about all that's been done to the 52 aside from powder coating a pair of dropped spindels for it that i havn't put in yet
i just realized two nights ago
i'f i'm gonna take this seriouse my car is gonna have to wait
don't make money working on it
until it's done a nd becomes a rolling advertisement
my time has been more into searching for parts for customer cars
ordering wiring harnesses and suspension parts for the 49
and i spent a day getting the 49 ready to pop the engine out
i have everything in good condition if anyone is searshing for anything under the hood
for 49-54 chevy
i'm picking up a mototr for it this week 350 sbc
th400 trans 10 bolt rear
waiting for a 4 link kit to arrive
also gonna be putting the body back on that 65 frame
after these are done i have
a 54 chevy coming in for bags
35 chevy for a 12 volt conversion
and 48 fleetline for a full restoration
a 61 caddy for bags
and maby a 37 chevy for bags
so yeah the 52 is puched into late nights after hours and freetime
looking to get that $$$$$$$ together
the shop is coming soon :biggrin:
nice to here things are starting to fall in place for you joe. ill also be putting up a shop on my land. kind of a side job, pocket money making, support my habit kind of shop. a 30 by 60 shop probably.
Discussion Starter · #13 ·
front end
hmmm
sway bar is 4 bolts on frame
and two on each end to the lower arms
lower arms are 4 bolts to frame and a ball joint
upper is two bolt to frame and ball joint
steering just take a picture
or ditch it all and do a box conversion
ditch the sway bar. it really doesnt do much it seems like. atleast with air anyways. once i took mine off, i could hit some wicked sides.to get the spring out, i would just us a jack under the arm, jack it up a little to compress the spring, then un bolt the ball joint. then slowly lower the jack. if you get worried about the spring hopping out of there and giving you a little kiss, just run a chain through some of the turns and then chain it to the frame.
Discussion Starter · #15 ·
or torch it
Discussion Starter · #18 ·
Originally posted by yodawagon@Sep 12 2005, 07:00 PM~3801655
have fun with the ball joints. i had a hell of a time getting those out.
yeah i seen some guy try to take out b- joints with the wrong tools
it was like watching a retard trying to fuck a door knob
tools needed will be
pickle fork on an air hammer is good but ok with manual hammer
or if you can get the assembly off the frame byt the arms and still not able to get the b joints loose, hit them out with a hammer
your gonna be getting some new ones anyways
Are there bushings in the front end that are going to need to be pressed in by a machine shop?
tippin' on 3
NO SHIT RIGHT!!! even after you grind off the rivets they still won't come out!
1 - 20 of 22 Posts
