1 - 20 of 100 Posts
Zip it cunt!
i just grabbed this pic at random, im trying to identify a few parts and understand how they work. any help is appreciated :)
1. what the hell is that thing? im assuming it goes to the cylinders, is it necessary? is it just like a fancy T connector?
2. what is it, is it neccesary
3. oil reservoir, yeah i know
4. pump motor, yeah i know
5. looks to be a slowdown valve
6. is a dump
7. what the heck is that little thing? is it neccesary?
8. and 9. im assuming those are the pressure and return ports, am i right?
shits confusing :(
6. is a dump
shits confusing :(
Hey Bro,
here's a good reading for you.
http://www.eternalrollerz.com/TechArticles/techpage.htm
has a whole section in the tech about various aircraft parts , function, and rebuilding some of them...
6. is a dump
shits confusing :(
1. Is a Pesco EQ used on two pump two dump setups ( just front and back) Makes a cool noise when you drop the car....
2. looks like a filter... not really needed...
3. Is a avatiors oxygen tank converted into a oil resivoir
4.Pesco 280 with a GE motor
5. Zig Zag slow down.... you have options on slowdowns some like them at the dump some at the return port on the tank
6. yes notice all three ports are used in this application.
7. that is a fuel filter used as a collecting jar to catch run off oil that seeps out of the gear head before it gets into the motor.. in the planes these were just hooked up to tubes that leaked under the plane..
8-9 Inlets and outlets... ;)
Hope this helps brother
flow of aircraft pump with 3 port square
Zip it cunt!
:worship: :worship: :worship: hell yeah that help, thanks a lot man.... again ;)
the master on airplane hydraulics has just taught you a big lesson :biggrin:
i have a ? could aircraft hydro still be used for opping and do anyone have ony old school pic of the setups
I love hearing "PAPA"
WOW!
Good work!
UH!!!
Man I got to have more free time.
Hey Jay, I just got another power pack panel, what happened to the image upload?
im still learning this whole aircraft deal and it is very cool and probably the only thing i would do on my cars from now on.one question i got is what kind of cylinders do i use? i read somewhere that you have to use a special kind which one do i use and why?
Not special cylinders, just fatter. You can get by with 1 to 1.25" on a small car if you take it easy on the switch. Or a pressure relief valve /accumulator to take off the pressure spikes on heaver cars. Just go up and down easy.
The pump heads were not made for the shock (pressure spike) of the fluid. It blows out the pumps.
thnx for the info should i go with showtime torpedos or from black magic?
It might just be me but I like the shape of pro hopper pumps better than pescos. I know there is always a quest to be different but I just cant get into the look of these pumps. I know the one in the picture is a little abused.
good ol trusty 777 thats what im running 3 777 1 3ft oxy tank 2 bullet accum 3 adel dumps 3 zigzag slowdowns and 3 purolator filters.
Well, I favor BMH. Nothing against PH, I like them too.
Hows the speed? Are they reliable? Whats different performance/maintenance wise from traditional hydraulics.
1 - 20 of 100 Posts
