i got 2 Pyle 6.4 inch in dash Tv's for sale here are the specs:
IN-DASH DVD CD CD-R CDR-W MP3 PLAYER SPECIFICATIONS
MP3, DVD, CD-R. CD-RW and SDVD Compatible
Wireless Remote Contol With Remote Infra-ren Eye
In-Dash Mounting Kit and Brackets
Cigarette Lighter Adapter
12 Volt DC Power System
RCA Audio Outputs
Multi-Langauge On-Screen Menue System
NTSC/PAL Compatible
Frequency Response: 20Hz to 20KHz
Signal-to-Noise Ratio: Greater Than 90dB
Dimensions: 6 5/16" x 6 3/16" x 2"
IN-DASH MOTORIZED 6.4" MONITOR SPECIFICATIONS
Motorized Eject/Flip-Up LCD Monitor
AM/FM Receiver & CD Changer Controller
In-Dash Unit Appears To Be Standard Car Radio
VHF/UHF Tuner
RCA Jacks For Easy Hookup Of External Video Sources
Audio & Video In & Out,
TV/AV Switch For Easy Switching Between Sources
Full Function Remote Control
Controls Pyle¤ Multi-Disc CD Changers
CD CHANGER SPECIFICATIONS
6 Disc automatic cd changer
8X oversampling digital filter
1 Bit twin d/a converter
3 Beam laser tracking system
Anti-skip suspension mechanism
Horizontal or vertical mounting
Trunk-to-dash interface Din cable included
ANTENNA SPECIFICATIONS
Interior Installation TV Antenna
Reception Channel: VHF-12CH (900MHZ-222MHZ) UHF 13-62CH (479MHZ-770MHZ)
Antenna Cable Length: 4.9m
Cable Terminal: 3.5mm
Antenna Impedance: Normal 75
Dimensions: Body- 500(L) x 36(W) x 13(H) mm
RCA Audio Outputs
NTSC/PAL Compatible
VHF/UHF Tuner
