1 - 20 of 32 Posts
You need to tell us what year,make,model number etc.....Come on we cant read your mind
What are you wanting to spend?
What are you wanting outa your system? lay an play or faster?
how are you going to setup your valves?On the tank or by the wheels?
Right off the batt,your going to need 4, 1/2'' or 1/2x3/8's'' male compression fittings for the bags.
They sell valves w gauges at the hardware store, joe pm me your # so I can text you the pics. I gotta have this done by the 19th
got mine from my local ag store in town,anyplace that deals with farm stuff should have them,or homedePOT.
pmed you.
^the only one I took lolI'm mounting the tank under the bed/between the frame. Can I use a hadley 160 psi compressor for a 5 gallon tank?
never heard about that comp?
Check out thisx site.Theres tons of guys cutting those trucks up.You biggest problem is gonna be the rear,an how your gonna address it.Are you gonna keep the leafs but just go do to a couple ( i wouldnt suggest Btw) or link it some way.
An really do you need a 10 switch set up? I had FBSS an honestly never used it.Mostly front an back
http://67-72chevytrucks.com/
1 - 20 of 32 Posts
