1 - 9 of 9 Posts
well i got started on it tonight, got the front tacked in
here are a couple pics of the front dropped and then the front with the a-arms locked out.. just curious what you guys think.. i think i got the power balls in the sweet spot on the lower control arms.
when laid out the cylinder is perfectly straight up and down and when it is up and the arms ar maxed out i think the cylinder tilts towards the motor 12 or so degrees,, also at no point does the cylinder shaft hit tha powerball...
if you have any suggestions or comments id really appreciate it!!
what kind of car/truck is it your doing the install on?
I have never seen a powerball used in the front before... why did you choose to use them? just curious... Your from Ont?
im runnin accumulators, no coils..
yup im from the london area..
you think it looks fine? i got it all tacked right now just waitin to weld it all in
Run your pump at low volatge and see if the cylinders binds up or anything and if not then go ahead and weld it in. Good luck.
Originally posted by Mr. White@Oct 21 2007, 08:17 PM~9052435
so how's the progress?
2003 ,yeah i think he should seriously be done by now. :cool:
1 - 9 of 9 Posts
