B
Guest
SHOULD I INSTALL THE SWITCH THRU THE HOT WIRE IN MY IGNITION OR THRU THE NEGATIVE SIDE OF COIL
is that how you make it so that the motor will crank, but the car will not start ? If not how ? ever heard of putting a mini toggle switch in the lighter ?
SPELL CHECK
I used to have one that was wired to the fuel pump relay, if I remember correctly. It was funny because the truck would start up and you could even drive it a couple feet if you were quick, but then it would stall (run out of gas) and you couldn't restart it. :biggrin:
