1 - 9 of 9 Posts
Hello :cheesy: !
How much can you bend 1/4" air lines (approx. bend radius) when running them through the interior of the car? The bit that might cause me problems is the step from under the rear seat to the rear floor.
Also, how much can you bend 1/2" lines? These probably won't be much of a problem, but I would be handy to know, because I would like to keep things tidy with my installation.
Thanks :cheesy: .
Originally posted by M-827@Nov 17 2003, 05:47 PM
Hello :cheesy: !
Thanks :cheesy: .
ask air280 hes supply the shit..
Face Puncher
1/4" will be somewhat flexible, but the 1/2" likes a big sweeping radius
Originally posted by oneclick@Nov 17 2003, 06:12 PM
not sure on 1/2" lines... but why are you running them inside the vehicle? it is always easiest to run them along the frame rails under the car...
Jason
I'm only running the 1/4" lines through the car to the gauges under the dashboard.
The 1/2" lines I will run through the chassis.
I presume air280 is Iain Sherriff, judging by the avatar. I've spoken to him a couple of times, but he's very busy with work (as is Ray at Rayvern), so I don't like to bother him too much. I like communicating with everyone on this forum anyway :cheesy: !
i see now... i thought you were running all your lines inside the car...
the "step" you are referring to... couldn't you just run them down the center of the car... on the hump? there shouldn't be much of a step there, just a thought...
Jason
That should be okay then. I was only really worried about the 1/4" lines.
Actually that's a good idea. I have already installed the wiring for my air suspension and stereo, which runs down either side of the transmission tunnel, so I was thinking of using the same route for the gauge lines.
With your idea I could run them onto the top of the tunnel by the rear seat, then gradually down the sides onto the floor if I need to.
:cool: :cool: :cool:
1 - 9 of 9 Posts
