1 - 12 of 12 Posts
hey, sometimes when i hit switches in thefront alot in my car it goes up oneside up at a time but after a while it stops doing it how could i prevend this frm happening again? i think it might be air in my setup by the way its 1 pump 2 the front
thanks in advance
y blocked. teed, how is it hooked up in front?
Originally posted by 3whlcmry@Aug 16 2005, 07:08 PM~3639474
someone of my back corner would be down a lil less then the other side from a 3 wheel but it feels level and when i dump it thaside goes down faster
well my car cant 3 wheel and im pretty positive its not it unlevel in the back so what else do u think it could be?
now i think i just have to guess, you run a y block or a tee in front right ? not running from one cylinder to the other. right? do you see any oil runnning down the cylinders at all? are the fittings wet at all ? I think you probably are getting air in there somewhere. unless a cylinder is bent a little. I could be alot of differant things but you didnt answer me so i guess i cant give you any ideas.
i kidnd of dont understand your question but im not using y's its just tees in my setup if thats what you are asking...
Banned
ARE YOU IN THE CAR WHEN IT DOES THIS?MAYBEE ONE SIDE OF YOUR CAR IS SLIGHTLY HEAVIER ..YA KNOW WHAT I MEAN.?.....MY NEON DOES THAT SHIT IF IM IN IT...BUT THEN AGAIN IM DAMN NEAR 300POUNDS...AND IM ONLY RUNNIN 24V TOO......BUT MY CADDY DID THAT TO DOUBLE PUMPED TO THE FRONT @72V...ANYONE ELSE EVER HAVE THAT PROB? OR AM JUST A FAT FUKER?
oh shit, ive nevr though of it that way, it very well could be, i weigh about 170 lbs but why does it only after i hit switches 4 a while?
1 - 12 of 12 Posts
