Im assuming you dont mean the kind of dolly you move boxes with...Originally posted by lowriderlife@Sep 29 2003, 08:56 AM
-----use a hammer and dolly-----use the hammer from the inside and the dolly on the outside-------
Im assuming you dont mean the kind of dolly you move boxes with...[/b][/quote]Originally posted by A-Run+Sep 29 2003, 12:48 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (A-Run @ Sep 29 2003, 12:48 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--lowriderlife@Sep 29 2003, 08:56 AM
damm bro - and that's what I was gunna say - a bit of hammer/doly work and a high build epoxy or polyester primer and some block work , and if you find it hard work with the hammer use a shim of filler .. :biggrin:Originally posted by lowriderlife@Sep 30 2003, 01:56 AM
those are easily fixed since you can get to them from the inside-----use a hammer and dolly-----use the hammer from the inside and the dolly on the outside-------just becareful not to make more dents----take it slow and work the metal------you might have to use a little filler once you get them pretty straight----sometimes just a good heavy prmier like polyester and lots of blocking can get them perfect after you have worked them out---hard to tell exactly how bad they ae from those pics----but they just look like push dents-----no biggy
damm bro - and that's what I was gunna say - a bit of hammer/doly work and a high build epoxy or polyester primer and some block work , and if you find it hard work with the hammer use a shim of filler .. :biggrin:[/b][/quote]Originally posted by sabre+Sep 29 2003, 05:19 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (sabre @ Sep 29 2003, 05:19 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--lowriderlife@Sep 30 2003, 01:56 AM
