1 - 5 of 5 Posts
I put it in the shop its $95.00 to get fixed is it worth it?
Crossfire BMF1000D Specs
Price & Contact: $779; 562-483-8111, www.crossfirecaraudio.com
All measurements @ 14volts unless otherwise specified
Frequency Response (4-ohm IHF Load, 100 Hz Ref. crossover @ highest setting}: +0 dB, -3 dB @ 241 Hz
L/R channel, max deviation 20 Hz to 20 kHz: N/A
Signal-to-Noise Ratio
0.29% @ 500 watts
Output Power (4 ohms): 475 watts @ 14 volts,
393 watts @ 12.8 volts,
254 watts @10.5 volts
Output Power (2 ohms): 808 watts @ 14volts,
656 watts @ 12.8 volts, 429 watts @ 10.5 volts
Output Power (1 ohm): 1233 watts @ 14 volts,
1013 watts @ 12.8 volts, 759 watts @ 10.5 volts
you found it?
in someones trunk right? lol.. jp man
well if retail is 795.. and they want 95 to fix it.. thats roughly 1/8 of the retail.. i say go for it..
I hate that series and when I worked at car toys we had trillions of these comin in. They actually discontinued this series and made a improvised version. It does not suprise me it doesnt work. LoL :uh:
1 - 5 of 5 Posts
