P
peezy
·Guest
Hey, dont know much about air cyls but is this a good deal?
"Hey i got a kit on nmy car i'll sell cheap. only thing it needs is new O-rings on the pistons in 3 of the cyls. I rebuilt one of them already, but had to use a new updated cyl (ports on bottom not on side for reverse flow) for parts to fix it. I have a set of O rings for the other front that should work. I also have a unused rear cyl that I can take apart for the 2 rear's fix. other than that, its a good working system with all new ARO 215 psi solenoids, big gold Blitzluft valves (like 5/8" exhaust ports) 1/2" line, 3/8" fittings everywhere else. 5 gallon tank, NEW Viair 450C compressor, water trap, 10 switch CCE box (front/back/side/side/pancake/f-r seesaw/individual wheel) and 80 amp relay & pressure switch. all heavy duty wiring. I'll even throw in a SVR-55 battery i use to keep it happy when the car isnt running.
You'd look at about $1400+ with this kit, its very fast. install an adjustable pressure switch and a oasis compressor and hit switches like hydros, but with no waiting. I will take $800 for the kit, and make sure everything is in good shape before i send it. I'll even send it with free shipping, and extra parts like compression fittings and inserts for the hose."
Anything other than getting the O-rings fixed that i will need to get this up and running? Check valves a good idea?
thanks for the input
p
p
