From last battery in series positive side, (say you got 3 solenoids) goes to left side of noid then small jumper from right side to the left side of the next and son until you get to the end of the third one. The end of the 3rd one goes to the motor on your pump. Same for the other pump. That will give you 36 volts to that pump. Solenoids - you take the motors wires from the switch box either front or back depending on which one and run those to the s side of the solenoid (small post on top) jump those across from noid to noid those stop at the noid. Dumps have two wires gound one to the pump (you can use the nut that holds the tank on) and the other goes to the wire from the swicth box that controls the corner your hsoe is hooked to . Some boxs require you to put the two front motor wires (from the box) together and the two back motor wires together depends on the wiring inside the box. YOU NEED TO KNOW WHAT WIRES GO WHERE FROM THE BOX. Everbody wires their boxes different
