1 - 20 of 24 Posts
I posted a few days ago about my front getting locked up. Well I'm still having the same problem even with someone else hitting the switches.
Some people suggested for me to run my dumps at 36V and if it continues then run 4 dumps to the front?
Can someone answer please!!!!!!
dont run anymore than 24 v and in what way is it getting locked up? is it getting stuck - stuckwhere u have to crack the hose to drop it or what?
The only time you can run 36v to a italian is if it has 24v on the solenoid part. Other than that you can run 36v to try and release the pressure from the dump but the easiest way is to crack to hose at the front.
Eric
sounds like your overlocking the suspension..bleed some pressure off
Is the cylinders over locking or are you pressure locking the system? Do the cylinders extend all the way?
Eric
damn you... you beat me to the punch on this one... :angry: ;)
i read your last post, i think you need to open up your slow downs,alot!
there are really only two things that will make your car do this while hopping
bad timing
and tight slowdowns
i say open them all the way and see if it still happens.
p.s. stop listening to whoever is telling you this 36v 4 dump crap
4 dumps wont make much of a diferance unless you have 4 return hoses and 4 return ports on your blocks :cool:
keep your switches at 24 volts and open your slowdowns up..... i bet thats it .....just gotta be good on the switch too
WHATS UP MAN CHECK ON YOUR COIL SEE IF IT READS 24V OR 12V THAT COULD BE YOU WHOLE PROBLEM.SOME COMPANIES SELL THE ITALIANS WITH 24V COILS AND THHAT IS WHAT HAPPENS WHEN YOU HAVE THEM.
I ran 36 to a Delta one time, it didnt last long, but it opened fast as hell.
But NO dont do it.
yea we found that out too, we put some 12v delta coils on when they locked , and it fix that problem . Change the coils, you need the juice to open them, and a 24v will lock up with the high pressure
Discussion Starter · #14 ·
1). I don't have any slowdowns what so ever.
2). If I put 4 dumps I'll have to put one of the returns on the tank opening.
3). I bled the system more than 6 times already and I also released the air that was pressurized in the tank through the air valve
4). I saw a cutlass (dancer) and he is using 36 volts and 4 dumps to the front.
5). My coils reads 24 volts
6). If I were to put 36 volts I'll put 2 solenoids sepreatly
well, then you are going to have to run a solenoid at 36 volts to the dump and use the power from the switch to activate the dump... either that, or put a 12 coil on it.
Originally posted by vegashopper+Dec 31 2003, 06:22 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (vegashopper @ Dec 31 2003, 06:22 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--WANNADANCE@Dec 31 2003, 06:20 PM
well, then you are going to have to run a solenoid at 36 volts to the dump and use the power from the switch to activate the dump... either that, or put a 12 coil on it.[/b][/quote]
we had 8 pumps in the rasing hell truck , and had the same problem . the dumps locked up after a couple hits. I notice that the tops were 24v, i told jhon to try some 12v tops to see what happens, all we had were some old delta tops , put them on and no more problems with that. so running 36v , and extra silinoids is the last thing i would try.
Originally posted by edmunds costoms hyd+Jan 1 2004, 10:07 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (edmunds costoms hyd @ Jan 1 2004, 10:07 AM)</td></tr><tr><td id='QUOTE'>
we had 8 pumps in the rasing hell truck , and had the same problem . the dumps locked up after a couple hits. I notice that the tops were 24v, i told jhon to try some 12v tops to see what happens, all we had were some old delta tops , put them on and no more problems with that. so running 36v , and extra silinoids is the last thing i would try.[/b][/quote]
You know as well as I do that people are gonna do what they want anyway... we did the same thing with Ron's truck, put 12 volt coils on it with the same result... no more problems!!!
G
Originally posted by edmunds costoms hyd+Jan 1 2004, 11:07 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (edmunds costoms hyd @ Jan 1 2004, 11:07 AM)</td></tr><tr><td id='QUOTE'>
12volt coils is the way to go! what up edmund! ;)
Originally posted by vegashopper+Jan 1 2004, 11:20 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (vegashopper @ Jan 1 2004, 11:20 AM)</td></tr><tr><td id='QUOTE'>
You know as well as I do that people are gonna do what they want anyway... we did the same thing with Ron's truck, put 12 volt coils on it with the same result... no more problems!!![/b][/quote]
yea i cought that in the photo shoot , in Ron's settup. Well at least were on the same page.
Originally posted by Equipped Customs+Jan 1 2004, 01:10 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Equipped Customs @ Jan 1 2004, 01:10 PM)</td></tr><tr><td id='QUOTE'>
12volt coils is the way to go! what up edmund! ;)[/b][/quote]
Whats up Jhon , hope you stayed out of troble last night . Play it safe, stood home , except for the dam fools shooting in the air at 12 o clock.
1 - 20 of 24 Posts
