1 - 10 of 10 Posts
autotek sx1200 amp (700watts) when the level is raised up on the amp..i keep blowing the inline fuse on the power ..fuse was a 30 i think .. would it be safe to upgrade it to a higher fuse.. with out the possibility of a fire
30 is way toooo small homie,, if you are running 4awg, run a 50-75 amp fuse or breaker.
-J
being that the inline fuse is there to protect the wire (so that doesnt burn up and do wierd shit)...
if your using a 4awg hot wire, do like 1ofaknd said and just flow with a 150 fuse (because a 4awg wire can handle 150)...
if your using an 8awg hot wire, use a 70 inline fuse (because an 8awg can handle i think its either 70 or 75, i know its one of those for sure though)...
or if you wanna do it by the books, add up the fuses you have on your amp, and the sum of that number will be the fuse rating of your inline fuse...if you cant get a fuse to match your sum, then get the next higher rated fuse to run...
but almost all ppl, myself included, match the fuse with what the wire can handle because thats why it there in the first place...
-qs
2GUNZ
We got into this before, about the fusing, and yes I do understand that the fuse is there for the wire, but I still think that you should not use a 150 amp fuse for a Amplifier that is rated at 80 amps. The reason that I like to go closer to the voltage of the Amp is so that if a short happens, then you will pop that fuse before your Amps fuses go. That way you don't lose both. Like in the case of Amps with Internal fuses, that shit is a bitch to get too.
gracias
/\ i could have sworn i already told you that....
-qs
i did, i did tell you that...
-qs
1 - 10 of 10 Posts
