ive got one of the mid level jl audio amps i think its 1400 1x400 noticed no bass the other day so went and checked the amp green light rcas have signal noticed when i touched the hz adjustment know bass came on then i took finger off and it went away, so im thinkin one of the connections inside by that area are loose or breaking off, ive had the amp for five years anyone ever run across this problem thanx
You would have to pull the cover off and look at the solder points of the potentiometer. This may require pulling the amp circuit board completely off in order to see if the connections are cracked. Can you take a pic of the area in mention or at least the board itself and post it?
i havent pulled the amp yet but the bass knob is no longer working for adjusment amp is wide open im running the gain at a quarter turn its got to be somethin inside that particular area of the amp so do i look for anything out of the ordinary or are there any tests i can do
