*** Its the same as Kandys ,,, only its cheaper than buying by the quart & mixing them to a small amount...I use these to custom mix small amounts of kandy for airbrushing.....I mix em with SG-100 intercoat clear ... When i need a larger amount I mix em with regular Urethane Clear Coat......
You cant paint a whole car muchless ANYTHING exposed to the sun with a candy concentrate. They have a very limited lightfasness. Go ahead and try if you want but they are only good for small amounts of airbrushing MAYBE graphics or mixed with kandy to paint door jambs in less coats
** I have never did an "overall" with a koncentrate ... I will just buy it from the paint store ..... I just have done some patterns & graffix with concentrates......
I've tested candy concentrates under heavy QUV testin and yalumba testin plants under severe weathering and yes if not mixed to the proper strength and used in the right way would be unsuitable for exterior -- :biggrin: :biggrin:
