#1
Model S10L7
Size (IN., CM) 10, 25.4
Impedance (OHMS) 2 DVC, 4 DVC
Max Rec Amplifier Power (WATTS PEAK) 1200
Max Rec Amplifier Power (WATTS RMS) 600
Sensitivity (dB 1W/1M) 85.4
Frequency Response (HZ) 24-100
Mounting Depth (IN., CM) 6-3/8, 16.2
Mounting Cutout, Square (IN., CM) 9-1/2, 24.1
Min Rec Sealed Box Vol (CU. FT., LITERS) .66, 18.7
Max Rec Sealed Box Vol (CU. FT., LITERS) 1.0, 28.3
Min Rec Vented Box Vol* (CU. FT., LITERS) 1.25, 35.4
Max Rec Vented Box Vol* (CU. FT., LITERS) 2.25, 63.8
*Port Volume Excluded
#2
• 10" Flame Q Subwoofer
• 120 oz. Strontium Magnet
• Power Handling: 900 watts RMS
• Frequency Response: 22Hz - 500Hz
• Efficiency: 95 dB
• PHAT 2" Multi-layer Foam Surround
• Stamped and Balanced Aluminum cone
• 2.5” Voice Coil
• Dual 4 Ohm
• 2 Ohm or 8 Ohm Operation
• Mounting Dimensions: Depth; 6” Hole; 9” Diameter; 10-1/4”
• Lug Lock Terminals
which one would you go with???? I'm lookin at a pair of 10's but i kinda like these both for now!
Model S10L7
#2
• Efficiency: 95 dB
• 2.5” Voice Coil
• Dual 4 Ohm
