1 - 8 of 8 Posts
Which size hoses and fittings would you use with this block.
It's correct that you must have lots of voltage in order to make this block worth using or else it defeats the purpose right?
1/2 inch :uh:
2GUNZ
At least 1/2". You could hook up some of those new Telescoping Cylinders. :cool:
1980 Cadillac Fleetwood 90’d out
Its better to start big at the pump. Then work your way down to the cylinders. The car I'm building now will run The L.A. blocks with 1" ports, 3/4" checks, 1/2 hoses, and then 3/8" ports at the cylinders
1 - 8 of 8 Posts
