can i get some tips on how to lay my truck on its frame with hydros i get the front (cut the springs) but the back shackels,and blocks and such only take it so low. any suggestions would be much apprieciated :biggrin:
:thumbsup:Originally posted by dayton roller@Sep 12 2003, 01:23 PM
if you wanna get real low you need to do a c notch in the rear 4 link it
you need to talk to hydrota he has a couple cool as trucks on juiceOriginally posted by tryin2getlow@Sep 12 2003, 03:13 PM
If he is wanting to lay frame then there would be no need to body drop it. Whether or not you need a notch the frame depends on the size of rim and tire that you are using. If you have lets say...155/80/13 then there is no need to notch the frame. Just monoleaf it and I use to run a 3" block too. Up front I had my coils cut to about 4 or 5 turns and it was pretty much on the ground. If you have bigger rims or taller tires than do what they said and install the notch and notch the frame for your arms. If you have the money I would recommend that you go ahead and get a fourlink too. Good luck with your truck and if you have any questions don't hesitate to ask.Originally posted by dayton roller@Sep 12 2003, 01:23 PM
if you wanna get real low you need to do a c notch in the rear 4 link it and body drop it
now your talkingOriginally posted by tryin2getlow@May 8 2006, 09:30 AM~5390001
i sold the truck for a 64 impala convert thanks for all the replies
