1 - 3 of 3 Posts
I WAS READING IN THE TECH AREA AND IT LOOKS LIKE I NEED A SPECIAL SETUP AND CYLINDERS TO DO AN INSTALL ON A CAR W/LEAF SPRINGS. IS THAT TRUE AND CAN ANYONE GIVE ME ADVISE ON THE BEST WAY TO DO IT?
Leafs are really esy to do, you put a bracket on the frame slide a coil over the cylinder, slide the cylinder in the bracket coil over style, then you just figure out where you want to attach the cylinder shaft. I use hymes joints attached to a piece of channel cut in half attached to my rear end.
1 - 3 of 3 Posts
