I remember reading a while ago about someone who had their pump mounting bolts penetrate the block and caused a leak right there. Is anyone able to find that thread, or does someone have insight to this? I've never had this happen to me, but I think it happened to someone I know....bad PH block machining?
are you sure its coming from there if the pumps are still in the car it take em out to check its not coming outa the bottom of the tank or from the motor side and running down
that has my vote
might have been my post, turned out the return port had cracked through to the mounting bolt for the motor, but it looked like it was leaking from pump mounting bolt
was a prohopper block, installed a BMH block now and all sweet! :biggrin:
To the rescue :biggrin: .
