with airbags. whenever u turn the wheel the bags squeaks.. almost sounds like when balljoint is going to fail on hondas.. its a 94 lexus es300
also the compressor kicks in right. but it kicks in for like 2 mins shuts off for like 10 secs come on agian.. so on and so on. thats without hittin the switch.. and the valve only lift the airbags only like half an inch...
shit is pissing me off. car is so fuckin low it bottoms out like crazy. and scrape alot of shit..
Do you have any pressure gauges? Do you know any details about the kit? Should have front struts. What kind are they. What kind of strut bearing. Sounds like you have some leaks or an electrical problem if the compressor keeps turning on and off.
says morone on the bags.. i dunno shit about this setup.. i just brought this car as is.. not an airbag guy,... more like hydros... but um why does the bag squeaks? makes a sound like it does on a honda with bag balljoint.. when u turn the wheel sounds like the an old door creepin open slowly..
Moron strut bags? never heard of them. It either has a bad balljoint of a bad upper strut bearing. Take it apart and see whats there for an upper bearing. The strut needs an upper bearing to turn without spinning the bag. Take some pics. Id guess its an aim strut.
i don't know if this is normal or not. but the compressor turns on when car is off will it drain the battery? also i could not hit the switch for 5 mins and compressor will still kick in.. so is it leaking or something??
The system will try to maintain a preset pressure in the tanks. When they leak it will turn the compressor on. They should not be connected to direct battery power as well. I wire all my cars to ignition so things like that cant happen. Either way, the tanks should not be leaking down like that.
