u know on regals that lil tab at the top of your window..well i just got done adjusting my door and now that stupid lil thing gets in the way of the window when u close the door..i bent it a lil and that helped but now it makes a noise when i shut my door...is there anyway to take these things off?
i think it helps to hold the window in. i hit it with a hammer and bent it upwards enough that i can shut the door without it hittin the window ;)
I don't know the really hi-tech reason why there is a tab, but it has something to do with the window and wind at hi-speeds. The correct proceedure would be to adjust the window... Take off the door panel and adjust the windows track, I believe it is the back adjusting screw that you would have to adjust. There is a way to take it off, but I believe it has a screw I would have to double check though.
yea i just bent it enough so that the window wouldn't hit when i shut the door it still holds the window straight when going fast but yea if u took that off i think your window might fall out cuz the wind would pull on it.
