1 - 12 of 12 Posts
for example shit starts sparkin cuz u hook something wrong up.
thats pretty much the only way besides mechanical failure
You 24 volt switch could burn if your batts are low or if they're not wired up correctly. I burnt mine up trying to run off of low batts.....then I slapped in an in-line fuse :biggrin:
going from two banks of batts and going from 48 ..to 72 and not moving the switch wire ...60 volts ...fried the switch in the lift position ...
threw a damper on my morning but lucky i had a spare switch figured it out and got to the show
the least amount is 24v the most is 24v....it is what it is
Face Puncher
i broke a switch in half while gas hopping, with real bad results :(
Originally posted by ExplicitDesignz@Aug 29 2005, 01:39 AM~3709815
So, whats the least and the most voltage you can send to a Carling?
i used one at 9.6 volts ...
for hopping a car model
i noticed the one i replaced ,the other day i was feeling around them ...and some of the black plastic is broke off in the middle on one side ..
them stock springs had good results for a minute on the freeway ...now i get no results ...
1 - 12 of 12 Posts
