1 - 15 of 15 Posts
What sound does it make if you are extremely low on hydraulic fluid or completely empty when you try and flip a switch?
it goes /////grrrrrrr!..................it grinds
If its low on fluid then it should sputter not grind......also depends how low ur fluid is.....y don't u just look n 2 ur pump wit a light n c uf ur fluid is low?
IT WILL GRIND!
open your tank plug, stick your pinky figner in the hole, if you fill fluid , your fine,, if not, add some... still don't work/sound right, then you have other problems..
Originally posted by pimpoldscutlass81@Aug 23 2006, 12:57 PM~6025246
you should get your computer smashed for that trick
it sounds like when you break a key, the motor just spins the pump and the car wont go all the way up.
:roflmao: :roflmao:
:roflmao: :roflmao:
Thanks for all the replies. This newbie appreciates it.
Is there anything I need to know before I remove the tank plug? Does the car need to be completely dropped?
~Individuals CC~
It sounds like gravel in your pumps... :(
yes, completely
Originally posted by BLACK MAGIC CUTTY@Aug 23 2006, 03:16 PM~6026231
yes, completely
Not to hijack this post but is it possible to add too much fluid?? Does there need to be an air pocket in the tank??.
good Q........ i never top mine off..... and theres no poblems wit perfomance.....
1 - 15 of 15 Posts
