i have the chance to get a free manual setup, i know it comes with 4 bags and all the fittings but i want to know if i can be able to raise and lower my car at will with it?????? i have some tanks and compressors i can use but i take it that there are no fast valves
if somone can just explain how a manual setup works exactly it would help me out alot
thanks Kev,
on a manual set up the switches are the airvalves that means where ever you have your switches therie needs to be room for what ever size air line your going to use it's like using ball valves the air is flowing through the switch they work prety smooth but it's well.... you see they wear quikly and leak easily depending on brand where are you getting them from
