i did my dodge truck with alsas metallic silver crazer a little over a month ago. i like it better than hok's because you don't need to use intercoat clear or adhesive promoter over it. i just did mine with plastic sheets, i was doing very large pieces at a time by myself, so saran wrap or anything else that is small was out of the question. applying the saran wrap is simple, you just shoot the marbelzer slightly wetter than normal paint, then either right away or after a minute or so just put the plastic directly on top of the marbelizer. once the plastic is on the wet paint, you can do whatever you want to it, press on it, give it tittie twisters, squeegee it, pull it, basically anything you can think of while its wet. then you just let it sit for a minute or two and peel if off, simple as fuck.
this is what it looks like right after you pull the plastic off
and after a little kandy and flake :cheesy: you can also just clear right over it if you want
also, usually you use a black base under marbelizer to get that traditional marble look, i wanted my shit to be real red and not stand out too much, so i just used the red base on my truck as the base for the marble.
