1 - 8 of 8 Posts
not to bad, at 210 i could hop a few time, shack it a lil, up and down all four and then it would be done
I was just doing some calculations based on (4) conti 2600's, with 12 gallons of air at 200 psi.
First lift of all 4 wheel will drop 200 psi to 159
second lift will drop to 126
third lift down to 100 psi
fourth lift down to 80 psi.
At that point depending on the weight of the car or truck it wont lift as high and speed will start to slow down considerably. I remember testing these pressures on the last 64 impala I did with 2600 stones all around and the #'s worked out the same. If anyone has a car with similar volumes compare them and see.
2500's wont take as much air to fill up, but take more pressur to lift as high as a 2600. As the pressure drops off it loses lift faster.
With 12 gall, and (4) 2500's at 200 psi it goes
200 to 173 on 1st lift
173 to 150 2nd lift
150 to 130 3rd lift
130 to 112 4th lift.
weight of the car will determine how much 112 psi with a 2500 will lift. In my experience the lift will be cut down dramatically.
Originally posted by 2003TownCar@Aug 31 2006, 09:08 PM~6082887
How much play time do you get with 12 gallons at 180 or 200 psi?
Also anyone got locked up pics of bagged cars?
lets see some pics of that vi mannie!
thats daddys customs olds.. not your average bagged vehicle :)
FULLY LOCKED
fully laid
just have to be smart about how you setup your cups and bag choice.
1 - 8 of 8 Posts
