1 - 16 of 16 Posts
Originally posted by b_diddy1@Jul 25 2005, 08:23 PM
Very cool. It is exciting to see air guys getting big hops.
[snapback]3478094[/snapback]​
anything off the ground. it was the only one gettin up like that
Originally posted by aleigh-n@Jul 25 2005, 10:08 PM
Moco's runnin his at around 300 psi, gets off the ground nice. I say go higher though
[snapback]3478420[/snapback]​
Car's not really built for that kind of stuff. I am not wanting to make it that crazy. Just want to be able to chip the tires at a stop light. I am not looking to break my shit. My setup is set to reach a max of 300 psi. (relief valve, etc.)
[snapback]3478555[/snapback]​
what type of a system are you running? like what size valves and lines? there is a guy on here that hops his at 180psi, like a 98 impala body style. hopping on air is easy to do, just like hydraulics, you just have to have the right air management set up. matt is also only running 1/2" valves as well on that i believe
[snapback]3499503[/snapback]​
What I have done so far ...
York - Engine Driven Compressor
5/8" OD Air Line
8 1/2" 470 PSI E-valves
EAI 0 - 400 Psi Adjustable Pressure Switch
12 Gallon - 8 - 1/2" Ports
Check valve rated at 300 psi and relief valve set to pop at 300 psi
Bags will be RS-62's up front to extended a-arms and 13" Bags in the ass.
1 - 16 of 16 Posts
