1 - 18 of 18 Posts
Im planning on buying a welder this weekend, and was looking at the millermatic 175. Now before i go drop a grand on a welder i want to know is it able of welding 1/4" steel to my frame with a strong weld? And also between the Millermatic 175 and the Lincoln Mig 175, which would you choose and why? both have almost the same specs..... here they are for the millermatic 175
Input Power
Requires 1-Phase Power
230 V, 19.5 A, 60 Hz
Rated Output
130 A at 20 VDC, 30% Duty Cycle
Output Power Range
30 - 175 Amps
Net Weight
73 lb (33 kg)
comes with......
Power source included
Power cord and plug.
10 ft (3 m), M-10 MIG gun and cable assembly with liner for .024 - .035 in (0.6 - 0.9 mm) wire.
10 ft (3 m) work cable and clamp.
Argon and AR/CO2 mix regulator/flow gauge with hose.
Sample spool of .024 in (0.6 mm) solid wire.
Two contact tips for .024 in (0.6 mm) wire and two contact tips for .030 in (0.8 mm) wire.
Dual groove drive roll for .024 in (0.6 mm) or .030/.035 in (0.8/0.9 mm) wire.
Factory-installed contactor and gas solenoid valve.
Information/settings chart.
hey ,that welder is just fine ...i have a miller challenger that i use to use ..and it worked great...from lowrider bikes ....tanks n skirts.....to 1 1/2 inch arm extensions...and i like the gaurantee that comes with the millers.....
Depending on how you grind your joints, you can use a 110 @ 80 amps with a 40% duty cycle if you're good. That miller is plenty good for you if you know how to weld
L8
G
L8
L8
Well im not great at welding. Only done it a few times back in high school with a sticker welder, So im gonna be learning, but im not jumping right on to the frame work. Ill fuck around with scrap metal and get the hang of it again before i touch my car .....
SINGLE PUMP NO WEIGHT
Get this.....I did two full frame wraps on my cars and another cars body on frame reinforcement plus many installs with a 110 fluxcore wire welder. It takes longer....but it still gets the job done.
yup i have done that......but now i got a new lincoln welder...
Originally posted by Chris+Jan 10 2004, 08:02 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Chris @ Jan 10 2004, 08:02 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--big pimpin@Jan 10 2004, 06:05 AM
yup i have done that......but now i got a new lincoln welder...[/b][/quote]
DAMN...I don't know wether to call both of you CHEAP or GOOD! :biggrin:
lol!
.....edit...oh yea that 175 will do you plenty fine ;) It'll push that metal, and you'll be a pro with an hour of practice
Discussion Starter · #13 ·
Originally posted by trudawg+Jan 10 2004, 07:17 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (trudawg @ Jan 10 2004, 07:17 PM)</td></tr><tr><td id='QUOTE'>
lol!
.....edit...oh yea that 175 will do you plenty fine ;) It'll push that metal, and you'll be a pro with an hour of practice[/b][/quote]
cool im gonna go pick it up on my next day off :)
I hope you didn't pay $1000 for it!! :0 I bought my Miller 210 shipped for $1187!!! ;) But of course that is US!! ;)
1 - 18 of 18 Posts
