wasnt sure what forum this fit best in, so i thought i post here too.......
Im planning on buying a welder this weekend, and was looking at the millermatic 175. Now before i go drop a grand on a welder i want to know is it able of welding 1/4" steel to my frame with a strong weld? And also between the Millermatic 175 and the Lincoln Mig 175, which would you choose and why? both have almost the same specs..... here they are for the millermatic 175
Input Power
Requires 1-Phase Power
230 V, 19.5 A, 60 Hz
Rated Output
130 A at 20 VDC, 30% Duty Cycle
Output Power Range
30 - 175 Amps
Net Weight
73 lb (33 kg)
comes with......
Power source included
Power cord and plug.
10 ft (3 m), M-10 MIG gun and cable assembly with liner for .024 - .035 in (0.6 - 0.9 mm) wire.
10 ft (3 m) work cable and clamp.
Argon and AR/CO2 mix regulator/flow gauge with hose.
Sample spool of .024 in (0.6 mm) solid wire.
Two contact tips for .024 in (0.6 mm) wire and two contact tips for .030 in (0.8 mm) wire.
Dual groove drive roll for .024 in (0.6 mm) or .030/.035 in (0.8/0.9 mm) wire.
Factory-installed contactor and gas solenoid valve.
Information/settings chart.
i have a miller matic 175 and it welds 1/4 just fine
