1 - 15 of 15 Posts
SPELL CHECK
I have moisture in one of the headlights of my '98 TC. I was going to remove the clear plastic lens section from the bucket to clean and dry it and properly reseal it. Some vehicles, this can be done simply by heating up the assembly in an oven, and then prying the clear lens from the bucket, but it doesn't seem so cut and dry on this assembly.
I noticed the clear part of the lens seems to have a black section around it, with like 2 clips on top, and another 1-2 on the bottom attaching it to the assembly. Do I need to remove that, or is there a way to get the clear apart from the black? Anybody ever try this method?
While fiddling around with the assembly, I tried to turn the thing to all different angles to try to trace where the water is entering, but the only place I could get it to drip from were the vents. :happysad:
homie, all I ever tried was drilling 2 very small holes in it and letting it
evaporate out...
evaporate out...
I'm not trying to be an asshole about it , but if the seal is leaking now why would you make more holes in the light to let in more moisture?
SPELL CHECK
evaporate out...
[/b]
Yeah, that's kind of a half-assed way of doing it, and I noticed that these headlight assemblies have vents on the back, so they SHOULD have air passing through anyway. I just don't know where it's getting in. :(
<!--QuoteBegin-61 Impala on 3
@Jan 25 2010, 11:00 AM~16403224
I am eventuaLly going to take mine apart too. Haven't looked to much into it but I know the lense does come off because there is a couple people that did HID coversation on them. It looks to me you would have to pry the tabs up after you put it in the oven to get the lense off.
Here is a link for the HID conversation. So it will give you an idea of how to reseal it.
Good looks bro. I'll check that out and see what I can learn. And if I do it, I'll post pics. :cool:
SPELL CHECK
Yeah, looks like that wasn't a TC headlight, just a generic how-to. The thing that's throwing me off is those tabs, and I sure as hell don't want to snap them off. :eek:hno: Looks like I just gotta try it and see what happens..... ;)
I was able to pry my tabs up and over a bit without breaking them. The hid can be done.
Look ;) :)
SPELL CHECK
Damn, $695?!? :eek: How much did it run you to do the job yourself?
I'd certainly consider doing the HID conversion if I'm going to pull them apart anyway. My lenses have a slight haze on them that I'm going to clean as well, but the night time lighting is dismal at best. :(
Yeah the price is way to expensive to buy out right. The most expensive part if you did it yourself would be the HID kit itself. There are a couple of headlight restoring kits out there to buff the yellow off the plastic.
i dont feel tardy
you drill them in the bottom so the water isnt trapped and it evaporates easier
its common to see because the lights going to fill with water again when you reseal it anyway
SPELL CHECK
[/b]
Yeah, I have a professional kit, but even wet sanding and polishing will work. :cool:
<!--QuoteBegin-REV. chuck
@Jan 26 2010, 01:32 PM~16416252
That's a half-assed way to do it, but very common. The weird thing is that the headlight assemblies actually have vent tubes on the back, which should let the water evaporate and escape, but it never does. Not before more water enters, anyway. :dunno:
i dont feel tardy
its condensation in the headlight and its going to continue to happen unless you give it some place to drain
i dunno about half ass it works
you know how your house windows get foggy inside the panes they do the same exact thing drill 2 small holes and blow compressed air with a cleaning chemical in it to unfog them they plug the top hole leave the bottom so it can drain
SPELL CHECK
Discussion Starter · #15 ·
Originally posted by lone star@Jan 28 2010, 06:29 PM~16443246
you know new headlights on ebay are about 100 bux or less
Yeah, but they're shitty repops, from what I've heard. Their fit and finish is questionable. :(
1 - 15 of 15 Posts
