1 - 20 of 24 Posts
The Great White Hype
Originally posted by BigBlue64@May 28 2011, 12:06 AM~20644359
Does anybody have a good tips to mold the trunk and hood without using metal.
try using Lead or all metal filler
I would just do the metal work though
what are you trying to do on the hood and truck see the problem is they are high traffic areas that will be slammed and shake. your metal work doesn't have to be perfect. there are lighter gauges you can play with if weight is an issue
or rivets and all metal brand filler
we cut small pcs of metal and use a glue to cover up da holes a lot easyer then welding hope this helps u
It can be done with metal without getting too heavy.
the hood hinges are strong enough to support a few more pounds anyway, I built an all steel cowl hood and molded the inside of the hood, added a lot of steel to it but it stays up easily.
most cars have these torsion bars to keep the trunk open, and usually they can be adjusted a little firmer so you wont have problems with a heavier trunk lid.
my homie molded his hood and trunk of his '78 having no problems being too heavy or anything
Originally posted by LostInSanPedro@May 29 2011, 03:16 PM~20652353
do you have pictures of this done?
i should by next week when its done
Originally posted by LostInSanPedro@May 29 2011, 03:22 PM~20652383
keep us posted, i saw a video recently that was talking about using glues just like this and had a hard time believing it. just sounds wierd to me.
THEY USE THIS KIND OF GLUE ON ALOT OF NEW CARS
im still waiting on pics, i wanna know how you paint over the glue?
Its called Panel Bonding Adhesive. If you use it to glue your sheet metal down, your then gonna have to fiberglass or use reinforce body filler to cover the seam. All in all, I think welding a sheet to your underside will yield better results and be less work on the bodyman. If not your going to be blocking that underside 20 times :yessad:
that is alot easeir to use n holds hella strong i worked in a dealership bodyshop n they use that adhesive to glue door skins n roofs together a good freind used it for my shaved door handles alot easeir n hold very good n is paintable gunna do it to my hood n trunk when i get back to the country
Banned
This^:thumbsup:
Panel bonding adhesive is for skinning doors,not shaving body panels.
1 - 20 of 24 Posts
