quite a bit actually, need to have the driveline worked on with a slip yoke installed, slip yoke is 200 i got it put onto the driveline for around 80, youll need to drop the upper trailing arm mounts, gonna need some adjustable uppers and lowers, depending on the size of cylinder u r gonna be using if u want get circus car lock up, youll want to relocate the lower trailing arm mounts up around the doors. many variables
