1 - 20 of 24 Posts
Aight I got a new motor, Hooked everything up right, hit the switches, and all i get is the silonoid clicking... So i cleaned up the ground cable, silionoids, and the rack, cuz i thought it might be a bad ground, Nope still dont turn, so i take the motor off open it up, and its as clean as a whistle, no dust and brushes look fine.. Its a prestolight motor, any one got any advice... Oh and sry if this shit been asked, just got no time for a search, need to get my shit going... Thanx for any advice.. need more info just ask..
just grab a 12v and jump start the motor and see if it goes. thats the easiest way to tell if its noid/wiring problems or not.
I tried that and the motor didnt turn, but its a new motor, so i dont know wtf is up.. what kind of wiring problem could it be.. and what kind of noid issue could it be if ive made sure i have a good ground?
charge batteries....not enough voltage. Bateries may not be good, they need to carry a ton of amps or they wont spin the motor. The current draw brings the batteries down to looow voltage. Hit the switch, check battery voltage when hit. If it drops way down and nothing....its your batts.
G
you really need to load test your battery's. you can buy a cheap load tester for around $30, even if a battery looks good on a charger it can still be bad. and one bad battery in your series is going to cause you problems
I think that it might be wiring issues, can you give me some hlep on that, what to look for, maybe its the noids
Aight, Question, good my noids be bad?Because there is no way its the batts, there all charged hot.. Could bad batt wires be a prob,, couldnt think of it being anything else... If any of this sounds possible please help me get juiceing agian....
G
:uh: did you load test your batterys ?
and that motor doesnt look new like you said
Move the batterys around, I'm thinking you might have a BAD CELL!!
They NEED to be Load tested!! :puffin:
DID THE MOTOR SPIN FREELY WHEN OFF THE PUMP? IVE HAD A SHITTY PUMP HEAD THAT REALLY SLOWED THE MOTOR DOWN.....I WOULD PULL THE MOTOR,AND GO TO THE CARS BATTERY NOT THE HYDRO BATTS GROUND THE MOTOR AND TRY 12V TO IT, IF NUTTIN THEN U HAVE A BAD MOTOR ;) IF IT WORKS CHECK YOUR WIRING
No actually i havent load tested, them do you think napa would have a load tester i could use? Or any local car shop?
Discussion Starter · #17 ·
Hmm... well ill try this, sounds safer than just usin the charger, and i guess the charger doesent always work on motors??.. why not try the hydro batts?
GetDwn
....because the batteries might be the problem. by using the battery cables from your running car, you'll see if the motor actually spins when 12v are applied.
but yeh, load test your hydro batteries. even though they might show that they are charged....they still might be f*cked
Discussion Starter · #19 ·
Aight, ill try load testin all the batts...
Discussion Starter · #20 ·
Aight got the batts load tested, and they are all good.... Hooked it all up and still nothin but noids clicken... then i went back to the setup and 2 of my noids were smokin and leaking some liqued, i disconected everything,... wtf is up.. some one got any advice... im replacing those noids today.. oh and i replaced all my batt wires, except for my ground quick release.. Any ideas??????
1 - 20 of 24 Posts
