yup ya got stuck solenoid,but ya might end up there agian if ya dont check your switches..are you runnin a fuse...are you runin 24 v to them if not then you need to and run a 10 amp fuse off the battery..to protect the wiring..if ya runnin a hoppin dump sometimes ya have to run a 15 amp but if not ,never go higher than a 10...also ..load test your first two batterries because if one of those is bad it will mess with your solenoids also....run a continuity tester on your switches after the 24 v wire has been disconnected from the battery and hit the switch to see how long it stays on after you let off of it..or just replace them if you ever ran more than 24 v to them....
good luck...
