1 - 16 of 16 Posts
I took my motor out of my monte to rebuild it,I put it back in started it and it worked fine, then I turned my key off and it was still running anyone know what the problem is? Is it the connection to my starter?I am stumped any help would be helpful.
the only thing the starter does is get the engine running to build compression :) so i dont think thats it. I dont know what it is, so good luck with it. The only thing my small brain can think of is that the ignition is messed up cause in my mothers old car (before i destroyed it) was stolen and they had to put a new one in and i could just take out the whole thing without anything happening.
Banned
does it run for a while, or does it sputter? if it sputters thats called dieseling, that means there is still a little fuel going to the motor i think. but now you know its called "dieseling" you can looking into it further.
did you rebuild the carb er even put a new one on, check to see if theres a bad smell comin from the pipe, well now wait... lemme ask you this. does it run normally after you turn the key off er does it jitter n make al sorts of old car sound fx , could also be an ignition problem mabe a bad solinoid er relay about to go answer me this than i can help you out. OH n try puttin in premium fuel n see what happens.
I put a new 800 edelbrock carb on when I turn the key off it just keeps running like the key was on.It doesnt sputter or nothing just keeps running.(sounds good though)haha
Banned
thanks for posting that last one, too many jerks come on here and ask for help and never thank the people who gave em the answers, makes me wonder if those other peeps ever read the answers people gave or if they got it fixed.
now dieseling can come form carbon build up on the cylinders whenit gets hot enought to burn it keeeps burning until it cools i guess...........but since you said you rebuilt it i have no idea lol..............did you hone the cylinders
1 - 16 of 16 Posts
