got a set of 20x8 fwd k-off wires and 225/30/20 tires. 2 of the tires mounted fine but on the other 2 about a 10 inch piece of the bead wont pop. any suggestions on how to get them to pop on?
Originally posted by 3whlcmry@Sep 23 2006, 07:08 AM~6228986
use a cheetah
didnt work
I have a wheel shop in Houston and when they dont seal we use "Murphys" mounting grease or air tool oil, lube it up real good and air it up the more pressure your compressor has the better we run at 200psi and hardly have that problem anymore. I know that it says dont exceed 40 psi while seating beads but being careful you can go up to about 50 or more and you will see the tire sealing then remove the air hose and step away for it to pop. Also you can break the one side that wont seal and put some oil on the rim itself.
