Ok i'm rulin out the pink wire. The pink wire is connected to the resistance wire that comes from the engine harness. The pink wire then connects to the starter solenoid. The red wire is now connected to a purple wire from the neutral safety switch. Can someone confirm all this is right?
dont forget your schottky diode coming off the regulator for your power. if its not there or built into the box, when you turn the ignition off, it will stay running..
