Originally posted by STR8RIDA@Jan 2 2009, 06:08 PM~12587872
the reason I said a presure washer is that you can see the paint edges flaking off in the pictures obviously it was sprayed over the paint job already on the car. who ever did it did not sand and prep the surface before hand - you can tell by the color underneath the peeling area is shiny as fuck - therefore in this case pressure washing it should peel it off. But as a general rule the other guys are right if done right murals are inside the paint and it would need to be repainted. But whoever did this to your ride half assed it and did a shitty job - would realy suck if you wanted to keep the art work but works out pretty good for you in this case. Good luck Lil Homie
thanks
its happend this way cause my uncle was an asshole to the painter
nd screwed his car
the only bad thing is its my car now
but im eventually gonna paint it a hypnotic blue
thaks for the advice guys
now i know the difference between paint and vinyl :biggrin:
